![]() | Home > Technical > Adding two stroke oil to fuel. yes/no |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1859 ![]() ![]() |
https://www.rrsport.co.uk/forum/topic54001...two+stroke 2023 P440e SE Dynamic on order -cancelled
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 425 ![]() ![]() ![]() |
Thanks but does not answer the question Always listen to old people or when they die you will live on in ignorance.
Probaly not, nor in the other 43 posts on the subject!
I think I read 400ml to a full tank Which is 200;1 which sounds a bit high Always listen to old people or when they die you will live on in ignorance.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Sounds the recommended ratio.
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 920 ![]() ![]() |
http://www.freel2.com/forum/topic22434.html?highlight=yamahafan
Brian Considine Member Since: 26 Mar 2022 Location: SE UK Posts: 93 ![]() ![]() |
I used to use Millers & never supermarket diesel.
I also use it and have done so since early on after the purchase of the car, some 7 years ago. From my experience it did nothing for the MPG, it did make it quieter and come MOT my emissions are incredibly low. Regarding the question its 200:1 I use. I've got a used water bottle with a long neck and have done the arithmetic and marked the bottle. It gets topped up to the mark. I put it in the tank whilst getting the disposable pump glove and then fill up. I only use regular shell diesel. 2006 2.7 TDV6 HSE in Cairns Blue. |
So there we have it 200:1...I was planning to use i on my next long trip across europe . Always listen to old people or when they die you will live on in ignorance.
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 ![]() ![]() ![]() |
Nothing wrong with adding to a tank full it was a common practice for me when running our old tdi on veg oil and then our tdv6 d3 on derv. Mind you I ran the old tdi on all sorts of stuff and it's still going at over 250k miles on original engine and injectors |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9025 ![]() ![]() ![]() |
Total snake oil nonsense.
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 ![]() ![]() ![]() |
We used to use it to great effect on an old straight 6, 3litre Opel Senator petrol engine.
Well that's you opinion, to which you are entiltled too, but then again you seem to have to have an opinion on almost everything. A local to me MOT Station often gets diesels that just fail the smoke test** - their advice is to run some two-stroke or Whynns through with a couple of tankfuls - guess what ? second time they pass. So, IMHO that quantifies as "empirical evedence". ** including well maintained diesels running on decent branded fuel. FWIW I've run new diesels for the past 30 years or so using either Millers or two-stroke - every single one has covered 250/350kplus miles, still running well and never, ever an engine issue with any of them. Wheras other people I know, who don't use additives have issues. What it boils down to is those that use additives will continue to do so (after all it cannot do any harm). Do you have any "empirical evedence" to the contrary ? Those that are against additives will not use them. You contradict yourself anyway by promoting "decent fuel" because the fuel companies themselves tell us they put additives in it ! 2006 RRS 2.7 HSE. |
