Home > General (L494) > Replacing pads with/without discs?
jamesgarbett
MOT has advised front pads are quite low
Garage has advised changing discs and pads as discs are lipped
Is this necessary?
Garage said you typically get thru 2 sets of pads for every set of discs
No idea on the history of my car in terms of discs/pads
Post #638539 Thu Jan 04 2024 5:31pm
Disco_Mikey
Replace the discs if they are worn Thumbs Up
Post #638540 Thu Jan 04 2024 5:39pm
gogsy1956
I'm sure the recommended minimum thickness is 27mm,,, the discs being 30mm new. They should be measured to find out exactly how big this lip is. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #638542 Thu Jan 04 2024 5:44pm
riverblanche
Hi,
there is no absolute answer from the info you have given Confused
if DM had done the MOT and said do D&P's then I would not question it and book in to have them replaced
but you know where you took it for the MOT and how much you trust them Question
if it was kwak fat or someone I would get the discs measured (ISTR most have the min thickness stamped into the edge of the disc) by someone I trusted and then decide.
if you know what your doing you can decide but if not then you have to trust the garage Question
and if it was a main stealer then they are probably fine for another 6 sets of pads Laughing
DM's shorter answer works "if Worn Replace" Laughing
gone Porsche Cayenne 2020
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #638555 Fri Jan 05 2024 4:30pm
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
Its not only the lip but the surface of the discs that matters..if you are doing it yourself its a no brainer. I bought set of pads and discs for the rear for £93 so I am sure you can get a deal on front ones and easier to fit than the rear as you have no hand brake drum to deal with Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #638558 Sat Jan 06 2024 7:35am
