Home > General (L494) > Replacing pads with/without discs? |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4418 |
Replace the discs if they are worn |
Thu Jan 04 2024 5:39pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 949 |
I'm sure the recommended minimum thickness is 27mm,,, the discs being 30mm new. They should be measured to find out exactly how big this lip is. 2010 RRS, TDV8
Thu Jan 04 2024 5:44pm |
Fri Jan 05 2024 4:30pm |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 419 |
Its not only the lip but the surface of the discs that matters..if you are doing it yourself its a no brainer. I bought set of pads and discs for the rear for £93 so I am sure you can get a deal on front ones and easier to fit than the rear as you have no hand brake drum to deal with Always listen to old people or when they die you will live on in ignorance.
Sat Jan 06 2024 7:35am |
