Home > General > Clonking from front nearside wheel |
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 215 |
Right, update time and a little red faced, though I must say it was 05:50 when I pulled up to the car park.
Mon Nov 27 2023 11:18am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9007 |
If it's a space saver then it's limited to 50mph, yes. If it's a full size spare then it's the same as the normal tyres. 2012 SDV6 - it's missing a couple of cylinders
Mon Nov 27 2023 12:03pm |
Thanks RRSTDV8, yes its a 255 on a 19 inch rim, so 50mph until tomorrows tyre fitting.
Mon Nov 27 2023 1:50pm |
255/50 on an 8x19 or 9x19 inch rim is full size so it's not a 50mph tyre. The 50mph tyres are something like 175/80 on a 5.5x19 rim. 2012 SDV6 - it's missing a couple of cylinders
Mon Nov 27 2023 3:24pm |
That's strange because there's a 50mpg warning label on the wheel, hmmmm.
Mon Nov 27 2023 7:30pm |
It is strange. I had similar on my spare back in the day. Full size 19in rim with full size tyre. My tyre supplier explained that the speed limit is a requirement of the small section tyre and if you're running a normal tyre on a suitable rim.then the speed limit doesn't apply. Could have been done where the car was supplied with 20in rims but a 19in spare in order to reduce the risks associated with slightly different tyres.
Tue Nov 28 2023 12:04am |
Yes, my wheels are 20 inch.
Tue Nov 28 2023 5:56am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5029 |
Yes, I have a 275/45 x 21" fitted so no problem.
Tue Nov 28 2023 7:43am |
Thanks Col, that's great
Tue Nov 28 2023 7:57am |
