Home > Technical > Elec Fault after Engine Swap
Last Boy Scout
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Good evening Troops.
Hope you’re all well.
Looking to pick some brains if possible….I recently swapped out my failed engine on my RR Sport 2010 3.0. (Turbo went…engine seized) After getting to the point where I’m ready to fire it up I’ve come up against an electrical fault….. the Ignition doesn’t seem to want to stay on and it won’t turn over.
The battery was goosed so I’ve swapped that out anyway. I’ve moved various relays around and checked fuses, etc. The earth is connected and seems ok. 400Amp fuse been replaced.
If anyone else has come up against this I’d be interested to know what the issue was and how you went about finding it.
Thanks in advance.
Post #637357 Thu Nov 16 2023 9:00pm
Have you cleared the fault codes.
Eg the seized engine one ?
Post #637358 Thu Nov 16 2023 9:04pm
Last Boy Scout
Good evening.
Thanks for the reply.
No I haven’t cleared the codes actually…I guess I assumed they wouldn’t have any effect after the battery was disconnected for so long. I’ll arrange for this to get done. You reckon this would cause the ignition not to stay on?
I’ve been told if the brakes haven’t been blead properly then this could be a a cause too…. Would / could that be a cause? Sounds like a long shot to me but happy to be proven wrong. Every day a school day when it comes to these things!!
Post #637380 Fri Nov 17 2023 5:33pm
Disco_Mikey
Try it Whistle Laughing
Post #637392 Sat Nov 18 2023 9:52am
Last Boy Scout
Will do. 😆
Will keep you posted.
Thanks again.
Post #637401 Sat Nov 18 2023 3:06pm
Last Boy Scout
Now then!
Bled Brakes…fault still there…. Messed round with other stuff… Bled Brakes again…. Turned over and started first time!! Ye ha!!!!! Yas!
Switched it off….problem returned… won’t start….
Bled brakes…. No joy….
Question is….what’s the best way to Bleed the brakes properly?? Smile
Post #637500 Tue Nov 21 2023 8:32pm
NoExpert
What’s it saying on the dash? Press brake when starting? If so just try smashing the brake pedal down a few times and hold it. Mine will usually start with barely tapping the brake pedal since it’s going off the electronic switch. However, now and then when I work on it it wants to read the pressure sensor and that can take a lot more force to trigger. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #637503 Tue Nov 21 2023 9:11pm
Last Boy Scout
Will give that a go mate.
Pretty sure it doesn’t say anything….Ignition On…. Press Brake…. Press the Bottom to start and it all just goes off.
Post #637511 Tue Nov 21 2023 11:45pm
Last Boy Scout
Sorted troops.
Bled the brake again…didn’t work…bled the brakes…didn’t work….bled the brakes again THOROUGHLY……starts every time. 🤷‍♂️🤷‍♂️
Got a fair bit of air out the Drivers rear.
That’s for help guys.
Have a good one.
Post #638207 Tue Dec 19 2023 9:05pm
