Home > Technical > Elec Fault after Engine Swap |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4984 |
Have you cleared the fault codes.
Thu Nov 16 2023 8:04pm |
Last Boy Scout Member Since: 27 Mar 2023 Location: Ayr Posts: 7 |
Good evening.
Fri Nov 17 2023 4:33pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
Try it |
Sat Nov 18 2023 8:52am |
Will do. 😆
Sat Nov 18 2023 2:06pm |
Now then!
Tue Nov 21 2023 7:32pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 485 |
What’s it saying on the dash? Press brake when starting? If so just try smashing the brake pedal down a few times and hold it. Mine will usually start with barely tapping the brake pedal since it’s going off the electronic switch. However, now and then when I work on it it wants to read the pressure sensor and that can take a lot more force to trigger. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Tue Nov 21 2023 8:11pm |
Will give that a go mate.
Tue Nov 21 2023 10:45pm |
Sorted troops.
Tue Dec 19 2023 8:05pm |
