![]() | Home > Technical > Elec Fault after Engine Swap |
Have you cleared the fault codes.
Last Boy Scout Member Since: 27 Mar 2023 Location: Ayr Posts: 7 ![]() ![]() ![]() |
Good evening.
Try it |
Will do. 😆
Now then!
What’s it saying on the dash? Press brake when starting? If so just try smashing the brake pedal down a few times and hold it. Mine will usually start with barely tapping the brake pedal since it’s going off the electronic switch. However, now and then when I work on it it wants to read the pressure sensor and that can take a lot more force to trigger. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Will give that a go mate.
Sorted troops.
