Home > Maintenance & Modifications > Change piston without removing the engine?
Pontus
Sweden 2012 Range Rover Sport SDV6 HSE Sumatra Black
Wonder if its possible to change piston without removing the engine. It should be plausible, but not sure if its worth it.
Post #636900 Sat Oct 28 2023 7:04pm
I’ve done it on a 2.7.
Difficulty is getting the upper sump out past the steering rack and up past the radiator.
Post #636901 Sat Oct 28 2023 9:03pm
NoExpert
Had to drop the diff on a 3.0 to get the pan out. Not terrible, not easy. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #636905 Sat Oct 28 2023 10:29pm
Pontus
Ok, good to know it's possible to do.
I can lift the body off and take the engine out, but it feels like too much work for just one cracked piston.
What would you choose to do if you will have to do it all over?
Post #636906 Sun Oct 29 2023 5:58am
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
Not too hard to take the steering rack off ...6 bolts.
Head off Sump off .If you can get to the offending cylinders big end bolts then it all comes out with the piston Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #636907 Sun Oct 29 2023 7:21am
I assume you have the head off already?
Or which side is cracked ? One with fuel pump drive ?
Post #636912 Sun Oct 29 2023 10:51am
NoExpert
We had a 3.0 SDV6 in with a blown up motor due to some clown not tightening the crankshaft timing pulley correctly on his recently replaced engine. It wasn’t too much effort to get one of the heads off. We then had to pull the axles and drop the front diff to get the pan out. Nowhere near as bad as getting in to a 3.6 TDV8. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #636920 Sun Oct 29 2023 12:32pm
