Home > Maintenance & Modifications > Change piston without removing the engine? |
Pontus Member Since: 04 Jul 2022 Location: Lövånger Posts: 3 |
Wonder if its possible to change piston without removing the engine. It should be plausible, but not sure if its worth it. |
Sat Oct 28 2023 7:04pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
I’ve done it on a 2.7.
Sat Oct 28 2023 9:03pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 478 |
Had to drop the diff on a 3.0 to get the pan out. Not terrible, not easy. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Sat Oct 28 2023 10:29pm |
Ok, good to know it's possible to do.
Sun Oct 29 2023 5:58am |
I assume you have the head off already?
Sun Oct 29 2023 10:51am |
We had a 3.0 SDV6 in with a blown up motor due to some clown not tightening the crankshaft timing pulley correctly on his recently replaced engine. It wasn’t too much effort to get one of the heads off. We then had to pull the axles and drop the front diff to get the pan out. Nowhere near as bad as getting in to a 3.6 TDV8. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Sun Oct 29 2023 12:32pm |
