![]() | Home > Maintenance & Modifications > Change piston without removing the engine? |
Pontus Member Since: 04 Jul 2022 Location: Lövånger Posts: 3 ![]() ![]() ![]() |
Wonder if its possible to change piston without removing the engine. It should be plausible, but not sure if its worth it. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
I’ve done it on a 2.7.
Had to drop the diff on a 3.0 to get the pan out. Not terrible, not easy. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Ok, good to know it's possible to do.
I assume you have the head off already?
We had a 3.0 SDV6 in with a blown up motor due to some clown not tightening the crankshaft timing pulley correctly on his recently replaced engine. It wasn’t too much effort to get one of the heads off. We then had to pull the axles and drop the front diff to get the pan out. Nowhere near as bad as getting in to a 3.6 TDV8. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
