![]() | Home > General > New owner sadly with an issue already!-TDV8 engine system |
TGJ Member Since: 04 Oct 2023 Location: Hants Posts: 13 ![]() ![]() ![]() |
I took it into these guys: https://more4x4ltd.co.uk/ Seemed to know their stuff, just very busy and booked up!. |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
Hmmm, I think the shorter distance between the application point and the actual location of the soot deposit, the better. I am really interested in how this works though, as the spray must travel through the cold side of the turbo, the intercooler, the combustion chamber (what happens there?) and eventually it reaches the hot side of the turbo where the soot resides. On the other hand, fuel additives also get injected to the combustion chamber, so almost the same story here. Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Most good ones are. I use Glenrands and equally as professional and busy ![]() ![]() * GONE. 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8 * GONE: 2011 4.4 TDV8 Full Fat. Amazing piece of kit. * Current. 1974 Lightweight 2.25L petrol. Old skool * GONE. Freelander GS TD4 Manual MY2013. Orkney Grey with privacy, cold and clearview packs, armrests (a must!) and a spoiler. * GONE. Range Rover Classic '93 200Tdi Factory fit * 1949 80" in family since 1975 |
DrDeAtH Member Since: 27 Jan 2020 Location: Herts Posts: 26 ![]() ![]() ![]() |
A good indication of a split intake is the fault code message: Boost correlation bank A
