Home > General > New owner sadly with an issue already!-TDV8 engine system
TGJ
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
DrRob wrote:
TGJ wrote:
Thought the best thing to do would be to get it plugged in at a Land Rover place
Who did you use in Hampshire as a matter of interest?
I took it into these guys:
https://more4x4ltd.co.uk/
Seemed to know their stuff, just very busy and booked up!.
Post #636399 Thu Oct 05 2023 5:30pm
TheWojtek
TGJ wrote:
I’ve got some of the Wynns turbo cleaner spray I’m going to use too, where is the best place to spray in on this car, undo the air intake pipes and spray there?
Hmmm, I think the shorter distance between the application point and the actual location of the soot deposit, the better. I am really interested in how this works though, as the spray must travel through the cold side of the turbo, the intercooler, the combustion chamber (what happens there?) and eventually it reaches the hot side of the turbo where the soot resides.
On the other hand, fuel additives also get injected to the combustion chamber, so almost the same story here. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #636403 Thu Oct 05 2023 7:49pm
TGJ
I’m thinking it’s got to be one of the inlet manifolds now, checked the actuators this morning, passenger side working fine, drivers side a little sticky but WD 40 applied and was all working fine.
I did get it go into limp mode after this and applying turbo cleaner (both the spray down the air intake and the one in the diesel tank) in fairness it did take much longer to come up today but it’s still doing it Censored
Post #636464 Sat Oct 07 2023 2:18pm
DrRob
Most good ones are. I use Glenrands and equally as professional and busy Thumbs Up Bow down Visitor from fullfatrr.com
Post #636498 Mon Oct 09 2023 11:54am
DrDeAtH
A good indication of a split intake is the fault code message: Boost correlation bank A
This means the right hand intake is most likely split. A quick visual way is to look at the fuel rail, if the injector pipes/nuts are sooty/oily, then you've found the fault. The intake splits along the seam under boost pressure, then it seals back up. Hence no fault upon restart.
Post #636963 Mon Oct 30 2023 9:06pm
