![]() | Home > Technical > Transfer box oil ...75w90? |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 493 ![]() ![]() ![]() |
Hey Pistnbroke, the oil in the transfer case is a special oil. It’s similar to 75w90, but has additives for the electronic clutch (more like removals similar to motorcycle oil with wet clutches). Have you drained the front and rear diffs and put in the correct oil for them? They’re also a 75w90 but nearly clear and also thinner than standard 75w90.
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 425 ![]() ![]() ![]() |
Thanks for that . Well if the 5w30 is bad news the |
