Home > Maintenance & Modifications > Two piece door handles question
savi18
New Zealand
Was going to buy the gloss black two piece door handles for my 09 Sport from PowefulUK for around £50 plus shipping to NZ, has anyone painted theirs if so what paint did you use, or is best just to buy them, cheers
Post #635208 Tue Aug 22 2023 12:31am
Unless you are going to try to paint then in situ. you will be very lucky to remove the small part of the handle cover in one piece as they go together quite easily, but the retaining lugs quite often break when removing them. I bought a set from PowerfulUK for that very reason as I need the the small part when I changed a door lock/latch and was the easiest and cheapest option as L/R one's are supplied primed only, meant have a couple of spare ones left as well
Post #635209 Tue Aug 22 2023 3:01am
savi18
New Zealand
Thanks Col, seen the video on PowerfulUK and looks really easy to remove but think I will buy ready painted ones, cheers
Post #635211 Tue Aug 22 2023 8:06am
Easy enough to change, don't show removing the small part though do they, I wonder why? Whistle
Post #635213 Tue Aug 22 2023 8:54am
savi18
New Zealand
Yep does show how to remove small plastic piece, I will try and post a link 2morro. Cheers
Post #635217 Tue Aug 22 2023 10:13am
Thumbs Up the video I looked at didn't show them removing the small part, be interesting to see how they do it. Might be my mistake and they are different on the 06-09 to 10-13 cars.
These are the little bits that snap off, stupid when the front passenger door one is just made to flip off to unlock it.
Post #635218 Tue Aug 22 2023 10:30am
peterjj
Australia
Broke the tabs off of mine (MY2008) when removing. I did read later that the safer way to remove is by removing door car and window and closing the clips from the inside. I found cheap replacements on AliExpress.
If you want a cheap way to get gloss black finish, sand the paint off, sand with increasingly fine sandpaper up to about 1500/2000 then buff with a machine and good compound. Pete
2008 L320 TDV8
2022 Hilux Rugged-X
Post #635245 Tue Aug 22 2023 11:02pm
savi18
New Zealand
https://www.powerfuluk.com/door-handle-ski...black.html
Post #635246 Tue Aug 22 2023 11:08pm
I think I would give the idea of removing the door card etc. a miss and buy new ones. Rolling with laughter
Post #635247 Tue Aug 22 2023 11:12pm
savi18
New Zealand
Doesn't show pulling of the small bit Col but if the small clips break if fitting new one's comes with new clips ,cheers
Post #635248 Tue Aug 22 2023 11:13pm
The clips are a integral part of the moulding and not separate so will be on the new one's, if the small piece simply just pulls off why didn't they show it? would only add a couple of seconds to the video? Very Happy
Post #635249 Tue Aug 22 2023 11:21pm
savi18
New Zealand
Yep true, they didn't pull off the small piece incase they did break and would have to replace with new at there cost,I would say the intregral clips break 90%, have just ordered the skins so hopefully be here in 2 weeks, cheers.
Post #635250 Tue Aug 22 2023 11:34pm
I suppose to be fair really doesn't really matter much if they break if someone is fitting new one's.
Post #635251 Wed Aug 23 2023 12:00am
