![]() | Home > Maintenance & Modifications > Two piece door handles question |
savi18 Member Since: 02 Aug 2015 Location: Gore. South Island NZ Posts: 148 ![]() ![]() |
Was going to buy the gloss black two piece door handles for my 09 Sport from PowefulUK for around £50 plus shipping to NZ, has anyone painted theirs if so what paint did you use, or is best just to buy them, cheers |
Unless you are going to try to paint then in situ. you will be very lucky to remove the small part of the handle cover in one piece as they go together quite easily, but the retaining lugs quite often break when removing them. I bought a set from PowerfulUK for that very reason as I need the the small part when I changed a door lock/latch and was the easiest and cheapest option as L/R one's are supplied primed only, meant have a couple of spare ones left as well
Thanks Col, seen the video on PowerfulUK and looks really easy to remove but think I will buy ready painted ones, cheers |
Easy enough to change, don't show removing the small part though do they, I wonder why? |
Yep does show how to remove small plastic piece, I will try and post a link 2morro. Cheers |
https://www.powerfuluk.com/door-handle-ski...black.html |
I think I would give the idea of removing the door card etc. a miss and buy new ones. |
Doesn't show pulling of the small bit Col but if the small clips break if fitting new one's comes with new clips ,cheers |
The clips are a integral part of the moulding and not separate so will be on the new one's, if the small piece simply just pulls off why didn't they show it? would only add a couple of seconds to the video? |
Yep true, they didn't pull off the small piece incase they did break and would have to replace with new at there cost,I would say the intregral clips break 90%, have just ordered the skins so hopefully be here in 2 weeks, cheers. |
I suppose to be fair really doesn't really matter much if they break if someone is fitting new one's.
