Home > General > Disconnecting battery to clean body earths |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5004 |
radio not coded.
Fri Aug 18 2023 2:16pm |
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 215 |
Thanks Andy, much appreciated
Fri Aug 18 2023 2:34pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5029 |
You will have to reset the window "one touch" operation easy enough, and the date on the display, as will default to 2009, if you have a sunroof will probably need to reset that as well but again easy enough.
Fri Aug 18 2023 10:35pm |
Hi Col, thanks, yeah I found that out when I reconnected the battery yesterday evening
Sat Aug 19 2023 8:07am |
