Home > General > Disconnecting battery to clean body earths
Jabba
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Hi folks,
Silly question, I would like to clean all the body earths, well as many as I can, I just wondered if its ok to disconnect the battery for a few hours whilst working my way through them. Would it being disconnected for a whilse cause any issues.
I'm guessing radios aren't coded any more.
Many thanks
Craig 2010 RRS 3.6 TDV8 HSE Galway Green
Post #635139 Fri Aug 18 2023 1:09pm
radio not coded.
Very wise to disconnect battery while doing this.
Post #635142 Fri Aug 18 2023 2:16pm
Jabba
Thanks Andy, much appreciated
Post #635144 Fri Aug 18 2023 2:34pm
You will have to reset the window "one touch" operation easy enough, and the date on the display, as will default to 2009, if you have a sunroof will probably need to reset that as well but again easy enough.
Post #635149 Fri Aug 18 2023 10:35pm
Jabba
Hi Col, thanks, yeah I found that out when I reconnected the battery yesterday evening Laughing
I cleaned the earth's behind the headlights on both sides, as I had the front bumper off check the front cruise sensor.
I plan to clean the rest over the next couple of weeks, ready for the winter.
I guess it was no surprise that the two earth points behind the drivers headlight were rusty, I manged to clean them ok.
Many thanks
Post #635159 Sat Aug 19 2023 8:07am
