Home > General > Dynamic Response - L320?? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5029 |
Deleted |
Wed Aug 09 2023 1:50am |
That's what I thought. Cheers Col |
Wed Aug 09 2023 2:34am |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
This could've been a no-cost option for the SC, as I have seen >2010 SCs without it and a paid option for the others (as I see it on my build sheet as optional). It is different hardware - suspension struts are dual-mode, obviously more expensive. Regards etc.,
Tue Sep 26 2023 7:21am |
Standard fittment on the 5.0L S/C, option on the 3.0L, not avaliable at all on the 5.0L n/a engine, I think it may have become standard on both the later 5.0 S/C and 3.0L facelift cars though.
Tue Sep 26 2023 8:02am |
was an option on the ephemeric 2010 TDV8 as well. Regards etc.,
Tue Sep 26 2023 10:21am |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 493 |
Struts are different, they have the electronic continuous variable damping and different six pin height sensors that send data to the air suspension module and the adaptive damping module. So while it’s “just a TR program” it does change the characteristics of the vehicle making it a more sporty feel in the suspension, accelerator, steering and transmission response, albeit not to everyone’s liking. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Tue Sep 26 2023 4:44pm |
camel_landy Member Since: 05 Sep 2010 Location: Swansea Posts: 68 |
Ah ha... Different struts.
Tue Sep 26 2023 6:36pm |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 |
"He is referring to Dynamic Response which is variable stiffness antiroll bars. DSC is standard on each and every RRS (in fact, it was mandatory for vehicles of this weight back then already)."
Mon Oct 02 2023 11:21am |
Land Rover called and asked for you to read your users manual again.
Mon Oct 02 2023 12:38pm |
Whatever you want to call it, ACE or dynamic reponse was not available on 5l nrmally aspirated engines even as an option. |
Mon Oct 02 2023 12:53pm |
You confuse DSC with Dynamic Response again, although the very thing you quoted is the simplest explanation of the differences between both. Regards etc.,
Mon Oct 02 2023 1:28pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9007 |
Mon Oct 02 2023 6:44pm |
XKCD #386 Regards etc.,
Mon Oct 02 2023 8:26pm |
