Home > General > Dynamic Response - L320??
300bhp/ton
Does anyone know what models have Dynamic Response as standard? Would a 3.6 TDV8 have it?
Anything to look out for with the Dynamic Response? Thanks.
Post #634899 Tue Aug 08 2023 8:41am
Main thing to look out for would be leaking arb bars and corroded pipes, I would think.
Post #634900 Tue Aug 08 2023 8:53am
Eaters
Re: Dynamic Response - L320??
If you are referring to the Dynamic Stability Control (DSC) then my TDV8 has it and I believe it was a standard item on the TDV8. Look for the DSC switch on the dashboard. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #634903 Tue Aug 08 2023 10:13am
TheWojtek
He is referring to Dynamic Response which is variable stiffness antiroll bars. DSC is standard on each and every RRS (in fact, it was mandatory for vehicles of this weight back then already).
According to 2007 brochure: standard on TDV8, 4.4 and 4.2 SC. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #634904 Tue Aug 08 2023 10:45am
Eaters
Aha! thanks Wojtek Thumbs Up Robin
Gone:
MGZTT 190 2.5
Post #634906 Tue Aug 08 2023 12:21pm
300bhp/ton
Many thanks for the confirmation. I assumed the TDV8 would have it as standard, but wasn't 100% sure.
Post #634907 Tue Aug 08 2023 2:33pm
Yes, the TDV8 has Dynamic Response.
Issues are really limited to leaking bars and pipes. Both can be sorted but can be a bit on the £££ side of things. Otherwise, it just works. 2012 SDV6 - it's missing a couple of cylinders
Post #634908 Tue Aug 08 2023 2:43pm
NoExpert
Are you looking for Dynamic Response or Dynamic Drive? 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #634912 Tue Aug 08 2023 3:27pm
300bhp/ton
What is Dynamic Drive?
Post #634914 Tue Aug 08 2023 4:14pm
NoExpert
Dynamic Drive is an additional Terrain Response mode in 2010-2013 L320’s (3.6 TDV8 was only available in 2010). It tweaks throttle response, transmission response, and suspension. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #634917 Tue Aug 08 2023 4:25pm
Is Dynamic Drive not simply another name for DSC.
Post #634925 Tue Aug 08 2023 8:43pm
TheWojtek
No, DSC is Dynamic Stability Control (fancy name for ESP).
Dynamic mode (available with Dynamic Drive option) is this:
 Regards etc.,
Wojtek
Post #634929 Tue Aug 08 2023 8:58pm
So how do you engage Dynamic Drive? as there is no mention of anything called "Dynamic Drive" in the handbook.
Post #634930 Tue Aug 08 2023 9:01pm
300bhp/ton
In either case, it was Dynamic Response, aka ACE 2 that I was interested in. But good to know about the other too.
Post #634933 Tue Aug 08 2023 9:06pm
Dynamic Drive is just a name someone has made up for the dynamic programme on TR, Col. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #634934 Tue Aug 08 2023 9:54pm
