Home > Technical > Access to front fog light - 2012 Red Edition l320 |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4982 |
As long as the screws underneath the bumper are not siezed, personaly I would drop the bumper off, really doesn't take that long and less trouble than taking wheels off and moving the wheel arch liner out of the way etc. etc. in my view.
Thu Jul 27 2023 9:07am |
TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 164 |
Thu Jul 27 2023 9:12am |
If I remember right I think the fog lights are held in with three screws which you might struggle to get at with just the headlight out, but as it takes about 30 seconds to remove headlight might be worth a shot.
Thu Jul 27 2023 10:02am |
Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163 |
Remove the headlights and grill - about 2 minutes flat - trust me im well practiced with having parking sensor issues a while back lol.
Thu Jul 27 2023 3:22pm |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 470 |
Just a question,
Thu Jul 27 2023 5:05pm |
Not to remove them, as they are screwed in from the rear so no access to the screws, just for reference alignment for the lamps is via the two holes under the lower edge of the bumper. Although I think on later cars you may have to remove headlamp to do it.
Thu Jul 27 2023 5:57pm |
Thu Jul 27 2023 5:59pm |
Eh up,
Thu Jul 27 2023 6:14pm |
Just make sure you have the self tapping screw out and give it a good yank it will unclip. Still wouldn't bother taking wheels off, I have changed bumpers on both pre-facelift and facelift cars and never taken wheels off.
Thu Jul 27 2023 10:42pm |
Yes mate, as Col said, there is a screw holding the bumper to the wing or bracket inside the wheel well, once removed it will pull away from the clips holding it to the wing, the bumper will need to be held away from the wing whilst you tilt the bumper or it will rub on the wings painted finish- if ya get what i mean.
Fri Jul 28 2023 7:54am |
Eh up
Fri Jul 28 2023 8:20pm |
Sat Jul 29 2023 5:19pm |
Eh up
Sat Jul 29 2023 5:42pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4966 |
Glad you went for yellows |
Sun Jul 30 2023 9:43am |
