Home > Technical > Access to front fog light - 2012 Red Edition l320
TTR
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Eh up all.
I just introduced myself and dropped a post into My Sport section yesterday.
From the great information on here I persuaded myself to re enter Land Rover ownership again.
I need to access my fog lights, given I have an Autobiography front bumper do I need to remove this from the car or :-
Can I remove the grille and headlight and get access that way ?
Can I remove the front wheel and inner wing and get access that way?
All help greatly appreciated and I look forward to contributing on here - it looks like a great forum with lots of knowledge members
Thanks in advance 👍
Post #634597 Thu Jul 27 2023 8:48am
As long as the screws underneath the bumper are not siezed, personaly I would drop the bumper off, really doesn't take that long and less trouble than taking wheels off and moving the wheel arch liner out of the way etc. etc. in my view.
Post #634599 Thu Jul 27 2023 10:07am
TTR
Many thanks- I take it access taking lights and grille out is a none starter ?
Will look at dropping bumper- just for experience with my X5 plastic clips and press fittings are not a good combination and I would hate to snap / break the bumper or fixings.
Thanks for the reply 👍
Post #634600 Thu Jul 27 2023 10:12am
If I remember right I think the fog lights are held in with three screws which you might struggle to get at with just the headlight out, but as it takes about 30 seconds to remove headlight might be worth a shot.
Post #634604 Thu Jul 27 2023 11:02am
Crraigymmmmm
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
Remove the headlights and grill - about 2 minutes flat - trust me im well practiced with having parking sensor issues a while back lol.
there is a screw on each side just inside the wheel arch for the bumper - should be able to get to on full lock easily enough (without taking wheels off) then there are 6 or 8 x 8mm head self tappers that hold the top of the bumper to the front member. I have learned that you can carefully pull the bumper away from the top and rest it on something in front of the car without taking the screws out underneith (like a small plastic step depending on which height setting your on) but will need a second set of hands to pull the sides of the bumper outwards enough to clear the wing as you lean it forwards. this will give you enough aceess to the spot lights. without fully removing it.
Post #634614 Thu Jul 27 2023 4:22pm
Autobiography1969
Just a question,
Do the round bits not pull out giving access from the front?
2012 Range Rover Sport Autobiography 3.0 SDV6 8 speed Automatic
Indus Silver with Hockenheim premium two-tone leather Ebony/Lunar,
Post #634616 Thu Jul 27 2023 6:05pm
Not to remove them, as they are screwed in from the rear so no access to the screws, just for reference alignment for the lamps is via the two holes under the lower edge of the bumper. Although I think on later cars you may have to remove headlamp to do it.
Post #634618 Thu Jul 27 2023 6:57pm
Autobiography1969
Bow down Thumbs Up ===========================================
Post #634619 Thu Jul 27 2023 6:59pm
TTR
Eh up,
Crraigymmmm - cheers for the advice will give that a go, do you need to unclip the side piece of the bumper as these are usually clipped / press fit into place .
Happy to give it a go, had the headlamps and grill of in minutes already it’s a doddle 👍
Otherwise it’s out with jack wheel and inner wing off - not ideal.
Cheers all - keep the advice coming in Thumbs Up
Post #634621 Thu Jul 27 2023 7:14pm
Just make sure you have the self tapping screw out and give it a good yank it will unclip. Still wouldn't bother taking wheels off, I have changed bumpers on both pre-facelift and facelift cars and never taken wheels off.
Post #634626 Thu Jul 27 2023 11:42pm
Crraigymmmmm
Yes mate, as Col said, there is a screw holding the bumper to the wing or bracket inside the wheel well, once removed it will pull away from the clips holding it to the wing, the bumper will need to be held away from the wing whilst you tilt the bumper or it will rub on the wings painted finish- if ya get what i mean.
TTR wrote:
Eh up,
Post #634628 Fri Jul 28 2023 8:54am
TTR
Eh up
Cheers both - I get what you both mean , will be giving it a go when it stop raining Rolling with laughter Thumbs Up
Post #634634 Fri Jul 28 2023 9:20pm
TTR
Eh up all
Thanks for everyone input on this thread.
It stopped raining today so had chance to get stuff done.
So - fog lights 🤔
I needed to get the headlights and grill out so popped them off anyway.
For my purposes I Managed to get access to both bulbs get them out and replace without taking the bumper off.
Drivers side - loads of room
Passenger a bit more difficult
I ain’t no elf hands either - more like shovels
I do not think I could have removed the light unit - definitely bumper off
Pics attached
Cheers for all the advice - hope this helps someone else
Post #634651 Sat Jul 29 2023 6:19pm
TTR
Eh up
Forgot to add swapped out bulbs 😃
Not sure it’s to everyone’s taste but they work a treat in fog - better than white in my opinion 😎
Thanks everyone
Post #634653 Sat Jul 29 2023 6:42pm
Glad you went for yellows Thumbs Up
Post #634669 Sun Jul 30 2023 10:43am
