Home > Technical > OBD scanner
Motorman
United Kingdom 2007 Range Rover Sport 3.0 TDV6 HSE Buckingham Blue
OBD scanner
Hi
I have a couple of annoying warnings and codes that wont clear with budget scanner, mainly water in fuel and EGR warning.
What scanner would you recommend that can go to the sub menus to clear these codes please
Thanks
Post #634409 Thu Jul 20 2023 6:07am
Goffy
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
If you just want to read fault codes and then clear them the iCarsoft LR works fine. I have the V2 but I see that there is now a V3.
If you want to do more, eg programming, then the general advice seems to be the Gap IID although I don't have one myself.
Good luck
Post #634477 Sat Jul 22 2023 3:29pm
Motorman
Many thanks
Post #634553 Wed Jul 26 2023 5:17am
