Home > Technical > Have I dropped a ****** ? |
Stand Easy Member Since: 10 Aug 2016 Location: Manchester Posts: 126 |
Hi all, a stupid question possibly but here goes, I bought a used front passenger door from a 2009 model that doesn't have the locking button in the outer handle, this is to replace a 2010 door that does have the lock button in the outer handle !
Sun Jul 16 2023 2:00pm |
172 have viewed this thread yet no one knows the answer |
Thu Jul 20 2023 4:07pm |
JDPRRSUK Member Since: 13 Apr 2023 Location: Leeds Posts: 266 |
Not sure but would think door would be same but you most likely will need to transfer handle and mechanism across. |
Thu Jul 20 2023 9:49pm |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 352 |
I would assume that the button is for the keyless entry system, therefore you’d need to swap over the loom from your old door to the new door, or at least check that both wiring looms are the same. |
Sat Jul 22 2023 7:32pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4969 |
The part number for the door is the same between the pre-facelift and the facelift cars, so as suggested would imagine just a question of swapping the wiring loom and lock/catch/handle assembly over.
Sat Jul 22 2023 10:59pm |
