Home > Technical > Have I dropped a ****** ?
Stand Easy
Hi all, a stupid question possibly but here goes, I bought a used front passenger door from a 2009 model that doesn't have the locking button in the outer handle, this is to replace a 2010 door that does have the lock button in the outer handle !
Have I dropped a Censored Embarassed or can I just transfer the lock mechanism over, maybe door wiring loom also ? Will the door itself be the same ?
Post #634310 Sun Jul 16 2023 3:00pm
Stand Easy
172 have viewed this thread yet no one knows the answer Question
Post #634429 Thu Jul 20 2023 5:07pm
JDPRRSUK
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
Not sure but would think door would be same but you most likely will need to transfer handle and mechanism across.
Post #634435 Thu Jul 20 2023 10:49pm
Stevepd
I don't have a clue, my take is that you could transfer it across. Thinking of manufacturing and the line assembly, it would be too inefficient to have two types for the same model (surely?). Go for it. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #634439 Fri Jul 21 2023 6:45am
JonnyCJ
I would assume that the button is for the keyless entry system, therefore you’d need to swap over the loom from your old door to the new door, or at least check that both wiring looms are the same.
Post #634484 Sat Jul 22 2023 8:32pm
The part number for the door is the same between the pre-facelift and the facelift cars, so as suggested would imagine just a question of swapping the wiring loom and lock/catch/handle assembly over.
Post #634485 Sat Jul 22 2023 11:59pm
