![]() | Home > Technical > Have I dropped a ****** ? |
Stand Easy Member Since: 10 Aug 2016 Location: Manchester Posts: 126 ![]() ![]() ![]() |
Hi all, a stupid question possibly but here goes, I bought a used front passenger door from a 2009 model that doesn't have the locking button in the outer handle, this is to replace a 2010 door that does have the lock button in the outer handle !
172 have viewed this thread yet no one knows the answer |
I don't have a clue, my take is that you could transfer it across. Thinking of manufacturing and the line assembly, it would be too inefficient to have two types for the same model (surely?). Go for it. 2006 2.7 TDV6 HSE in Cairns Blue. |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 430 ![]() ![]() |
I would assume that the button is for the keyless entry system, therefore you’d need to swap over the loom from your old door to the new door, or at least check that both wiring looms are the same. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5062 ![]() ![]() ![]() |
The part number for the door is the same between the pre-facelift and the facelift cars, so as suggested would imagine just a question of swapping the wiring loom and lock/catch/handle assembly over.
