Home > Faults & Fixes > Tailgate Close Button Conundrum
gdbevan
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Lux Stornoway Grey
Right, so I've got a 2011 (L320) RRS that is causing me a headache (like most RRS owners I have no doubt).
The issue is this. So the tailgate opens fine with the remote and the button on the dash, and closes fine when you pull down manually on the handle on the left in the boot (so it's not a struts issue) but the damn close button doesn't work.
I've replaced it with a tested and working button from ebay, and all to no avail. There's no signs of the loom being damaged, no signs of rust, no signs that the fuse has blown.
I'm at a loss. It just doesn't want to bloody work. Any ideas?
Post #633839 Tue Jun 20 2023 2:06pm
Scrumpy
Not sure it helps but just a thought if everything seems to work fine on it's own.
There is a safety feature that stops you auto closing the boot if there is a risk you would lock the keys in the car or an obstruction of some sort.
I'm guessing you have tried whilst standing outside of the car with the key? As, because of the safety feature mentioned above, it won't auto close if you are sat in the car with the key.
Other than that, I can only think it is picking up an "obstruction" of some sort? Or the sensor is faulty/mis-aligned.
Good luck. 2016 RRS SVR Estoril Blue
Post #633841 Tue Jun 20 2023 4:06pm
Is it the one piece or the split tailgate? only a suggestion, but if it's the one piece have you tried resetting the height opening setting to see if that does anything.
Post #633844 Tue Jun 20 2023 8:24pm
gdbevan
Hi, it's the one piece tailgate, but nothing happens when I try to reset. No beeps, no noises, nothing. It's as if there is no signal getting to the button. Which is weird because there's obviously a signal getting to the tailgate because the catch releases from the dashboard and the remote.
Post #633846 Wed Jun 21 2023 8:03am
Have you had the fault codes read? as there are quite a few listed for the tailgate control module.
Post #633847 Wed Jun 21 2023 8:39am
gdbevan
I didn't get the code, but the mechanic said it was the button. This is why I'm so confused.
Post #633848 Wed Jun 21 2023 10:01am
There would appear to only be three wires on the close switch, signal, earth and illumination, so if you have changed the switch and no change, then I would initially trace the signal wire to the tailgate control module for a break, unfortunately it's a black wire so there are probably a lot of them in the harness.
Another option would be to put a bridge wire from pin no.1 on the switch to pin no.23 on the tailgate control module to bypass the harness and see if that does anything.
Post #633868 Wed Jun 21 2023 10:14pm
