![]() | Home > Faults & Fixes > Tailgate Close Button Conundrum |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
Not sure it helps but just a thought if everything seems to work fine on it's own.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5032 ![]() ![]() ![]() |
Is it the one piece or the split tailgate? only a suggestion, but if it's the one piece have you tried resetting the height opening setting to see if that does anything.
gdbevan Member Since: 03 Dec 2019 Location: Higham Ferrers, Northamptonshire Posts: 4 ![]() ![]() ![]() |
Hi, it's the one piece tailgate, but nothing happens when I try to reset. No beeps, no noises, nothing. It's as if there is no signal getting to the button. Which is weird because there's obviously a signal getting to the tailgate because the catch releases from the dashboard and the remote. |
Have you had the fault codes read? as there are quite a few listed for the tailgate control module.
I didn't get the code, but the mechanic said it was the button. This is why I'm so confused. |
There would appear to only be three wires on the close switch, signal, earth and illumination, so if you have changed the switch and no change, then I would initially trace the signal wire to the tailgate control module for a break, unfortunately it's a black wire so there are probably a lot of them in the harness.
