![]() | Home > Technical > Flat Battery |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9026 ![]() ![]() ![]() |
Have you checked the external switch for the upper tailgate glass hatch? These are known to corrode and cause issues.
Paul_hst Member Since: 13 Jul 2021 Location: North Yorkshire Posts: 9 ![]() ![]() ![]() |
Thanks, when you say externl switch to you mean the glass tailgate release switch ? |
Yes. 2012 SDV6 - it's missing a couple of cylinders
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Could be an alternator drain.
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134 ![]() ![]() |
Hi,
Or try this.
Thanks for all the info, will investigate further |
