Home > General > My front ACE pipe burst this morning :(
Kevchenkho
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Hi guys. New here.
I bought a 2010 sport privately 3 weeks ago and now have a big issue with it. I took a mechanic with me and he said it looked clean underneath. Unfortunately when I went out yesterday one of the ACE pipes burst behind the front wheel. I know this is a costly fix and a massive bill I could be doing without right now.
Can anyone recommend someone in the central Scotland area that could perhaps fix this? I’m giving a couple of indi garages tomorrow to get rough quotes.
Thanks and apologies if I have put this in the wrong area.
Kev.
Post #632240 Mon Apr 10 2023 2:54pm
Disco_Mikey
Bigger problem is supply of parts ATM
I'm waiting on a set for a customer, 8-10 week wait apparently
Post #632241 Mon Apr 10 2023 5:03pm
karlos01
if you got any hydraulic hose suppliers near you see if they can make you some up
Post #632247 Mon Apr 10 2023 6:47pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
You can proberly repair it with a high pressure fitting
Post #632248 Mon Apr 10 2023 6:47pm
Kevchenkho
I went to Robbie fluid in Bathgate today and they would only supply a pipe and fittings if I brought my broken but in. The garage I’m using only wants to work on it if I’m replacing them though (which is understandable) but, yeah, I’ve spent all day searching with no luck.
Looks like I’m gonna have to take it off the road for a while.
Post #632255 Tue Apr 11 2023 2:05pm
Kevchenkho
Managed to temporality fix it. Sanded the pinhole area down, covered it with araldite then quick steel clay, then clamped a bit of hose round it.
Seems to be holding ok.
Not the prettiest but it will do till the pipes eventually come.
Post #632505 Wed Apr 19 2023 3:27pm
