Home > General > My front ACE pipe burst this morning :( |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4419 |
Bigger problem is supply of parts ATM
Mon Apr 10 2023 5:03pm |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 |
if you got any hydraulic hose suppliers near you see if they can make you some up |
Mon Apr 10 2023 6:47pm |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 |
You can proberly repair it with a high pressure fitting |
Kevchenkho Member Since: 10 Apr 2023 Location: West Lothian Posts: 6 |
I went to Robbie fluid in Bathgate today and they would only supply a pipe and fittings if I brought my broken but in. The garage I’m using only wants to work on it if I’m replacing them though (which is understandable) but, yeah, I’ve spent all day searching with no luck.
Tue Apr 11 2023 2:05pm |
Managed to temporality fix it. Sanded the pinhole area down, covered it with araldite then quick steel clay, then clamped a bit of hose round it.
Wed Apr 19 2023 3:27pm |
