Home > Maintenance & Modifications > ACE pipes
RRAS
ACE pipes
Hi Folks,
Just purchased a 2012 RR Autobiography Sport however just found out I need front ACE pipes (right). I’m having no luck locating any. Does anyone know where I can get any…would also buy second hand ones! Part number LR015144….thx
Post #632075 Sat Apr 01 2023 8:31pm
Disco_Mikey
Currently back order...
Post #632077 Sat Apr 01 2023 9:35pm
RRAS
You mean there is a wait on them..How long of a wait? Cheers
Post #632079 Sat Apr 01 2023 9:55pm
Jabba
Upto 10 weeks apparently 2010 RRS 3.6 TDV8 HSE Galway Green
Post #632081 Sun Apr 02 2023 6:21am
RRAS
Flip…can any temporary measures been done to stop the leaking…anywhere that may sell second hand / aftermarket ones in the meantime (leaking quite badly)!!
Post #632084 Sun Apr 02 2023 8:54am
JonnyCJ
Can you see where it’s leaking ? If so you could cut out the leaky section and repair it ? Google ACE pipe repair Range Rover Sport and see what comes up.
Post #632090 Sun Apr 02 2023 10:25am
RRAS
I’m not really mechanically minded so need to get someone to check if that’s possible! I have googled it but not much joy out there as far as I can see…was hoping someone on here who would know more than me could point me in the right direction!
Post #632096 Sun Apr 02 2023 12:53pm
JonnyCJ
Here’s the repair on a Disco 2. I’m sure if you call a specialist near you they should be able to get you running around until new pipes come in.
https://www.google.co.uk/search?q=ace+pipe...IUfNbiddSw
Post #632099 Sun Apr 02 2023 1:57pm
RRAS
Thank you…just hope some one will try and tackle it in the meantime!
Post #632102 Sun Apr 02 2023 3:43pm
RRAS
Have tried a few though don’t think any mechanics here in Northern Ireland want to go near the pipes and do this!!
Post #632141 Wed Apr 05 2023 10:30am
JonnyCJ
PM sent re NI garage connection.
Post #632143 Wed Apr 05 2023 10:47am
RRAS
Thank you
Post #632144 Wed Apr 05 2023 12:45pm
kas982
United Kingdom 2005 Range Rover Sport Supercharged Bonatti Grey
get pipes made by this company
Post #632189 Fri Apr 07 2023 10:17am
RRAS
I gave them a ring but fella who answered said they couldn’t help!
Post #632191 Fri Apr 07 2023 4:28pm
JonnyCJ
They absolutely can help, however you need to go in to them with exactly what you need. In your case it would be a section of ACE pipe and ask them to make up some compression fittings to enable the repair.
Unfortunately you’re not sufficiently knowledgeable about where the leak is, or how to use the compression fittings (not a criticism, just an observation).
I’m not sure what diameter the ACE pipes are, but it’s not rocket science to shape some kunifer tube to the existing spec.
I had some oil cooler pipes made up for an Aston Martin out of stainless steel. £100 for the pipe, custom bending and fittings. Aston wanted £700 for mild steel which would corrode like the originals.
A lot of stuff can be re-manufactured if you’re prepared to spend some time learning and investigating.
Post #632194 Fri Apr 07 2023 6:35pm
