Home > Maintenance & Modifications > ACE pipes |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
Currently back order... |
Sat Apr 01 2023 9:35pm |
RRAS Member Since: 01 Apr 2023 Location: Northern Ireland Posts: 10 |
You mean there is a wait on them..How long of a wait? Cheers |
Sat Apr 01 2023 9:55pm |
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 204 |
Upto 10 weeks apparently 2010 RRS 3.6 TDV8 HSE Galway Green |
Sun Apr 02 2023 6:21am |
Flip…can any temporary measures been done to stop the leaking…anywhere that may sell second hand / aftermarket ones in the meantime (leaking quite badly)!! |
Sun Apr 02 2023 8:54am |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 348 |
Can you see where it’s leaking ? If so you could cut out the leaky section and repair it ? Google ACE pipe repair Range Rover Sport and see what comes up. |
Sun Apr 02 2023 10:25am |
I’m not really mechanically minded so need to get someone to check if that’s possible! I have googled it but not much joy out there as far as I can see…was hoping someone on here who would know more than me could point me in the right direction! |
Sun Apr 02 2023 12:53pm |
Here’s the repair on a Disco 2. I’m sure if you call a specialist near you they should be able to get you running around until new pipes come in.
Sun Apr 02 2023 1:57pm |
Thank you…just hope some one will try and tackle it in the meantime! |
Sun Apr 02 2023 3:43pm |
Have tried a few though don’t think any mechanics here in Northern Ireland want to go near the pipes and do this!! |
Wed Apr 05 2023 10:30am |
PM sent re NI garage connection. |
Wed Apr 05 2023 10:47am |
Thank you |
Wed Apr 05 2023 12:45pm |
kas982 Member Since: 03 Oct 2021 Location: west mids Posts: 53 |
get pipes made by this company
Fri Apr 07 2023 10:17am |
I gave them a ring but fella who answered said they couldn’t help! |
Fri Apr 07 2023 4:28pm |
They absolutely can help, however you need to go in to them with exactly what you need. In your case it would be a section of ACE pipe and ask them to make up some compression fittings to enable the repair.
Fri Apr 07 2023 6:35pm |
