![]() | Home > Maintenance & Modifications > ACE pipes |
Currently back order... |
RRAS Member Since: 01 Apr 2023 Location: Northern Ireland Posts: 10 ![]() ![]() ![]() |
You mean there is a wait on them..How long of a wait? Cheers |
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 225 ![]() ![]() ![]() |
Upto 10 weeks apparently 2010 RRS 3.6 TDV8 HSE Galway Green |
Flip…can any temporary measures been done to stop the leaking…anywhere that may sell second hand / aftermarket ones in the meantime (leaking quite badly)!! |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 428 ![]() ![]() |
Can you see where it’s leaking ? If so you could cut out the leaky section and repair it ? Google ACE pipe repair Range Rover Sport and see what comes up. |
I’m not really mechanically minded so need to get someone to check if that’s possible! I have googled it but not much joy out there as far as I can see…was hoping someone on here who would know more than me could point me in the right direction! |
Here’s the repair on a Disco 2. I’m sure if you call a specialist near you they should be able to get you running around until new pipes come in.
Thank you…just hope some one will try and tackle it in the meantime! |
Have tried a few though don’t think any mechanics here in Northern Ireland want to go near the pipes and do this!! |
PM sent re NI garage connection. |
Thank you |
kas982 Member Since: 03 Oct 2021 Location: west mids Posts: 53 ![]() ![]() ![]() |
get pipes made by this company
I gave them a ring but fella who answered said they couldn’t help! |
They absolutely can help, however you need to go in to them with exactly what you need. In your case it would be a section of ACE pipe and ask them to make up some compression fittings to enable the repair.
