![]() | Home > General (L494) > Sport went bang! |
A1GSS Member Since: 16 Sep 2011 Location: Saffron Walden, Essex, UK Posts: 152 ![]() ![]() ![]() |
Sounds like a diesel runaway eating its own oil. Given the recent oil cooler work I’d be going back to the place that did the work. Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Crs Member Since: 04 Sep 2022 Location: Hampshire Posts: 82 ![]() ![]() ![]() |
Yes does sound like a runaway, have you had the DPF light on much |
John1311 Member Since: 05 Jul 2012 Location: Devon Posts: 40 ![]() ![]() |
no dpf light at all since ive had it 2016 Range Rover Sport SDV6 autobiography (MY17)
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4452 ![]() ![]() ![]() |
Turbo failure, I expect... |
Would that cause a runaway? Gone: 10MY L320 RR Sport HSE, Ipanema Sand
so have I got away with just new turbos or will the engine be damaged ? 2016 Range Rover Sport SDV6 autobiography (MY17) 2017 Range Rover Velar First Edition SDV6 2015 Range Rover Sport Autobiography 4.4 2012 Range Rover Sport SDV6 HSE Luxury Black |
You won't know until it has been assessed
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 474 ![]() ![]() ![]() |
What’s a diesel runaway? |
Friend of mine had an Isuzu pick up, it would re gen the DPF a lot which resulted in to much diesel getting in the oil which can cause run away on the engine, Isuzu would put another mark on the dip stick and if your oil level reached that mark you had to change the oil, at the time I had the same vehicle with the same problem, I sold mine after that, one of the reasons I brought a petrol Range Rover. |
https://en.wikipedia.org/wiki/Diesel_engine_runaway Gone: 10MY L320 RR Sport HSE, Ipanema Sand Gone: 20MY Jaguar iPace HSE, Silicon Silver Gone: 17MY RR Evoque SE Tech, Loire Blue Gone: 08MY Discovery 3 XS, Stornoway Grey Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey |
Wow, scary stuff. It’s enough to put you off buying a diesel……… |
So that sounds like new engine / recon and new turbos in that case ? 2016 Range Rover Sport SDV6 autobiography (MY17) 2017 Range Rover Velar First Edition SDV6 2015 Range Rover Sport Autobiography 4.4 2012 Range Rover Sport SDV6 HSE Luxury Black |
Do you have any sort of warranty on the car? |
Let’s hope it’s not runaway, which would be the worst case scenario, my l494 sport is the petrol supercharged, I have had my share of problems with it to be honest , currently got a bumping sound sometimes from the back somewhere . I wish you luck with your diagnosis.
