Home > Technical > 07 RRS - Turn on igition to start car, goes completely dead.
ondafly
Ireland 2007 Range Rover Sport TDV6 HSE Java Black
But then Smile
Hop out, open bonnet, have a look to see if the terminals are still connected to the battery. Get back in car and it starts (clearly rebooted the system though, as clock 00:00). Voltmeter reads 14v when running.
Am I looking at a dodgey battery at this point ? or is there a sensor somewhere I need to check ? or is it a simple case of poor connection at the battery terminals ?
Happy New Year anyway Smile
Post #629684 Fri Jan 06 2023 5:10pm
NoExpert
Make sure terminals are clean and tight. However, 14v seems low as mine pushes 14.6v-14.8v. Check your battery voltage before starting next time, should be around 12.8v if healthy. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #629690 Fri Jan 06 2023 7:18pm
The battery should be checked with a suitable diagnostic machine - a simple voltage reading doesn't tell you about how healthy the battery is.
As mentions, 14V when idling is a bit low. 2012 SDV6 - it's missing a couple of cylinders
Post #629697 Fri Jan 06 2023 11:56pm
ondafly
just to follow up on this - and not leaving it in the ether !
Positive terminal was loose - it must have been loosed up by myself when I was attaching the trickle charger in December. Also upon further checks voltage was reading 14.5 - 14.7 when running.
So the old L320 - still to this day has not left us stranded ever ! Thanks for your advice.
Post #629947 Mon Jan 16 2023 2:56pm
Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #629950 Mon Jan 16 2023 3:21pm
aln101
Scotland 2012 Range Rover Sport SDV6 HSE Lux Orkney Grey
Just bought a 2012 and got home after a 5 hour journey.
Poked around under bonnet and noticed battery cover melting at one spot.
Found the positive terminal loose and terminal burning hot!
These terminals with a stupid cone nut can't ever be tightened properly.
Surprisingly it started and ran fine like that.
Alan
Post #630384 Sat Jan 28 2023 9:42pm
kas982
United Kingdom 2005 Range Rover Sport Supercharged Bonatti Grey
yup, they are trash,i'm looking to add one of those security type clamps, will post an update in a week or 2
Post #630385 Sat Jan 28 2023 9:59pm
