Home > Technical > 07 RRS - Turn on igition to start car, goes completely dead. |
NoExpert Member Since: 28 Jan 2022 Location: PoznaĆ, Poland Posts: 478 |
Make sure terminals are clean and tight. However, 14v seems low as mine pushes 14.6v-14.8v. Check your battery voltage before starting next time, should be around 12.8v if healthy. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Fri Jan 06 2023 7:18pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
The battery should be checked with a suitable diagnostic machine - a simple voltage reading doesn't tell you about how healthy the battery is.
Fri Jan 06 2023 11:56pm |
ondafly Member Since: 03 Mar 2017 Location: Ireland Posts: 50 |
just to follow up on this - and not leaving it in the ether !
Mon Jan 16 2023 2:56pm |
2012 SDV6 - it's missing a couple of cylinders
Mon Jan 16 2023 3:21pm |
aln101 Member Since: 28 Jan 2023 Location: Argyll Posts: 49 |
Just bought a 2012 and got home after a 5 hour journey. Poked around under bonnet and noticed battery cover melting at one spot. Found the positive terminal loose and terminal burning hot! These terminals with a stupid cone nut can't ever be tightened properly. Surprisingly it started and ran fine like that. Alan |
Sat Jan 28 2023 9:42pm |
kas982 Member Since: 03 Oct 2021 Location: west mids Posts: 53 |
yup, they are trash,i'm looking to add one of those security type clamps, will post an update in a week or 2 |
Sat Jan 28 2023 9:59pm |
