Kzwpoas1
![](templates/vbnew/images/spacer.gif)
EGR Valve failure, pipes and seals. Part numbers | |
Hello,
So, my 2009, RRS, L320, 3.6 TDV8 broke down again! This time loss of power and "engine system" fault warning.
Turns out I need both EGR valves replacing. I will buy 2 aftermarket ones online as the original LR ones are eye-wateringly expensive. I will get the Magneti Marelli ones for about 160 euros each.
However, I have been told that I need replacement air pipes ( x4, 2 on each side) and 2 smaller seals ( quoted 15 eur for the 2) and 2 larger seals ( quoted 105 eur for the 2).
I can't find the part numbers for the additional pipes and seals.
Has anybody also changed both EGR's with all the additional parts?
Thanks.
Andy
Wed Jan 04 2023 12:28pm |
Kzwpoas1
Thanks for the link. Took me a while to get used to it but very good once worked out. Found what I needed.
Best wishes to sunny Norfolk. I am based in Europe but went to school in Holt.
Wed Jan 04 2023 3:12pm |
