Home > Technical > EGR Valve failure, pipes and seals. Part numbers
Kzwpoas1
Hello,
So, my 2009, RRS, L320, 3.6 TDV8 broke down again! This time loss of power and "engine system" fault warning.
Turns out I need both EGR valves replacing. I will buy 2 aftermarket ones online as the original LR ones are eye-wateringly expensive. I will get the Magneti Marelli ones for about 160 euros each.
However, I have been told that I need replacement air pipes ( x4, 2 on each side) and 2 smaller seals ( quoted 15 eur for the 2) and 2 larger seals ( quoted 105 eur for the 2).
I can't find the part numbers for the additional pipes and seals.
Has anybody also changed both EGR's with all the additional parts?
Thanks.
Andy
Wed Jan 04 2023 1:28pm
karlos01
Thanks for the link. Took me a while to get used to it but very good once worked out. Found what I needed.
Best wishes to sunny Norfolk. I am based in Europe but went to school in Holt.
Wed Jan 04 2023 4:12pm
karlos01
your welcome like said I just use for part numbers so can shop about
I don't live that far from holt
Wed Jan 04 2023 8:05pm
stozertom
HI, check out EGR VALVE in Technical, October 2022. It may help. Good Luck...........TomL
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
