Home > Faults & Fixes > Electrical issues
amgmaj
United Kingdom 2010 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Electrical issues
Hi everybody
Can anyone PLEASE help with some information (FIX) regarding my brother's 2006 RRS 2.7 the rear left side brake light and front left side headlight flash when he brakes and if he's use's the indicators?
We changed the left rear brake light n left headlight with my 2010 RRS and the problem still existed but put his lights on my RRS they worked fine.
Change the battery for a new one today made no difference.....
Similar problem to this video please see clip
https://www.facebook.com/reel/862567145111869?s=group_other
Thank you
Post #628636 Sun Nov 27 2022 10:46pm
TheWojtek
False ground on wiring somewhere. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #628644 Mon Nov 28 2022 10:53am
No ground on the rear left light unit
Post #628646 Mon Nov 28 2022 10:59am
amgmaj
Where about's would that ground be on the rear left?
Thank you for your reply
Post #628648 Mon Nov 28 2022 11:28am
Well assuming it's not a fault with the light unit or the light to car connector?
I guess the easy solution is to run a new wire in from the car. (removing the trim at the side of the boot will reveal earth points) either to check or to connect a new wire in. Unless of course you can find an external earth point. (which maybe a quick fix, but may not last long in the damp), but good to prove the problem
Post #628651 Mon Nov 28 2022 12:35pm
amgmaj
Brilliant will give that go hopefully its a easy fix.
Thank you once again
Post #628653 Mon Nov 28 2022 12:41pm
