Home > Technical > Steering wheel vibration when braking
NoExpert
Have you checked all control arm bushings (front and rear). 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #634414 Thu Jul 20 2023 7:49am
Crraigymmmmm
United Kingdom 2012 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
I had the same issue, I went trough discs, track rod ends and the problem was still there. Turned out to be bottom arm bushings, the hydro bush had split and emptied so I replaced with solid bushing and the problem has gone, I did fit new OE bottom ball joints too but the old ones seemed fine, so I would say it was 100% the rear hydro bushes that were causing the wobble when braking.
Post #634415 Thu Jul 20 2023 8:03am
giacomo.m
Italy
Front lower arms news,
i have to check the others, but could it also depend on the rear ones.....?
thank you
Post #634416 Thu Jul 20 2023 8:11am
NoExpert
Yes, essentially the tail wagging the dog. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #634457 Fri Jul 21 2023 4:09pm
giacomo.m
Italy
Hi all, update
after a year and about 15,000 km and after grinding the front discs the problem recurs: at 100/120 km/h pressing the brake pedal lightly the steering wheel vibrates......
so I rechecked some components:
no play on tie rod end and spindle connecting rod
full alignment
run-out of the front discs: 10/100 on dial gauge
new front lower control arm bushing
do I have to resign myself to replacing the front brake discs without ever finding a cause....?
thank you
Giacomo
Post #645896 Mon Dec 23 2024 2:08pm
JonnyCJ
Check that the disc mounting screw isn't sticking out just a little bit. It needs to be either recessed in the hole, or flush. Even just a tiny fraction will mean that the wheels don't go on flush to the hub. The wheels will always be in balance when checked off the car, but you'll introduce some variation if your screw isn't flush when you mount them.
Post #646058 Fri Jan 03 2025 11:59am
giacomo.m
Italy
Thank you Jonny CJ
I already checked, and unfortunately the screws are well screwed in and flush.....
Giacomo
Post #646068 Fri Jan 03 2025 8:53pm
