Home > Technical > Steering wheel vibration when braking |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 485 |
Have you checked all control arm bushings (front and rear). 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Thu Jul 20 2023 7:49am |
giacomo.m Member Since: 04 May 2016 Location: Roma Posts: 11 |
Front lower arms news,
Thu Jul 20 2023 8:11am |
Yes, essentially the tail wagging the dog. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Fri Jul 21 2023 4:09pm |
Hi all, update
Mon Dec 23 2024 2:08pm |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 385 |
Check that the disc mounting screw isn't sticking out just a little bit. It needs to be either recessed in the hole, or flush. Even just a tiny fraction will mean that the wheels don't go on flush to the hub. The wheels will always be in balance when checked off the car, but you'll introduce some variation if your screw isn't flush when you mount them. |
Fri Jan 03 2025 11:59am |
Thank you Jonny CJ
Fri Jan 03 2025 8:53pm |
