Home > General > Thinking about buying an RRS and have questions? |
DRW Member Since: 10 Nov 2022 Location: Brecon Posts: 33 |
Hi
Tue Nov 15 2022 4:38pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9010 |
4. The major issue with modern Land Rovers is the LR dealership workshops. Avoid them by using a decent independent LR specialist and you'll have far fewer problems. If you do have problems, they'll likely be sorted in one visit rather than several that is often the case with LR dealerships. If you insist on using a LR dealership, you will get very familiar with their customer waiting area and "free" coffee.
Tue Nov 15 2022 5:03pm |
snerkler Member Since: 14 Nov 2022 Location: Chesterfield Posts: 31 |
Thanks for the info, much appreciated. |
Wed Nov 16 2022 8:36pm |
Thanks. With regards to servicing and repairs I’d have to check the small print of the PCP deal as I believe some specify it has to be main dealer. |
Wed Nov 16 2022 8:37pm |
I guess if you're just renting it then it's less of a worry. 2012 SDV6 - it's missing a couple of cylinders
Wed Nov 16 2022 10:04pm |
With PCP you're still responsible for the upkeep.
Thu Nov 17 2022 7:47pm |
Oh, one other question. Do all HST’s have the Suede steering wheel and if so can these be swapped out for a leather one, and roughly what cost? |
Thu Nov 17 2022 8:36pm |
Hi
Sat Nov 26 2022 12:25pm |
All the used 3.0l P400's all seem to be HST, I've not been able to find the 3.0l P400 in any other variant. |
Sat Nov 26 2022 12:58pm |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1849 |
It was available as HSE, HSE Dynamic and HST
Sat Nov 26 2022 1:24pm |
PM sent, thanks |
Sat Nov 26 2022 5:05pm |
