![]() | Home > General > Thinking about buying an RRS and have questions? |
DRW Member Since: 10 Nov 2022 Location: Brecon Posts: 33 ![]() ![]() |
Hi
4. The major issue with modern Land Rovers is the LR dealership workshops. Avoid them by using a decent independent LR specialist and you'll have far fewer problems. If you do have problems, they'll likely be sorted in one visit rather than several that is often the case with LR dealerships. If you insist on using a LR dealership, you will get very familiar with their customer waiting area and "free" coffee.
snerkler Member Since: 14 Nov 2022 Location: Chesterfield Posts: 31 ![]() ![]() |
Thanks for the info, much appreciated. |
Thanks. With regards to servicing and repairs I’d have to check the small print of the PCP deal as I believe some specify it has to be main dealer. |
I guess if you're just renting it then it's less of a worry. 2012 SDV6 - it's missing a couple of cylinders
With PCP you're still responsible for the upkeep.
Oh, one other question. Do all HST’s have the Suede steering wheel and if so can these be swapped out for a leather one, and roughly what cost? |
Hi
All the used 3.0l P400's all seem to be HST, I've not been able to find the 3.0l P400 in any other variant. |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1856 ![]() ![]() |
It was available as HSE, HSE Dynamic and HST
PM sent, thanks |
