Home > General > Thinking about buying an RRS and have questions?
snerkler
I currently have an F15 BMW X5 x30d M Sport and have started looking at petrol Range Rover Sports (SVR, HSE/HST, Autobiography) and have some questions. My budget will probably stretch to a 2018/19 model:-
1) Is the suspension in the SVR much harsher than the HST and Autobiography, and would I notice a harsh ride compared to my X5. I assume all the RRS’s have air suspension?
2) Is the 3.0l P400 a decent engine or does it not have enough power/torque for this kind of vehicle?
3) Apart from fuel economy and insurance is the SVR more expensive to run?
4) Are there any major and/or common issues to look out for? I know they used to have air suspension issues, is this still the case?
Any help appreciated.
Post #628249 Mon Nov 14 2022 7:29pm
DRW
Wales
Hi
In my experience in answer to your questions.
1. The SVR has a sportier ride than the Autobiography, it makes a difference on wheel size, although the SVR is on larger alloys, as to the ride I have not experienced an SVR but can confidently say the ride is a lot smoother in a RRS as the X5 has always been set up for road handling, the RR is a true off road vehicle, it gives you the best of both worlds.
2. I have never owned a Petrol RRS.
3.As the SVR is a performance vehicle then probably will be using tyres and Brake componants on a regular basis, all RRS are not inexpensive to run although there are some good Indy workshops out there, it depends on whether a LR Service record is important?
4. The easiest way to answer is that it is a Land Rover Lol Big Cry , although BMW etc have their share of issues, probably best to purchase one from a Land Rover Dealership as it will come with a JLR warranty which is good unless you own a Diesel vehicle as certain components are not covered but that is another story Lol
I hope that helps and I am sure the SVR owners will be only too glad to help.
David
Post #628260 Tue Nov 15 2022 4:38pm
4. The major issue with modern Land Rovers is the LR dealership workshops. Avoid them by using a decent independent LR specialist and you'll have far fewer problems. If you do have problems, they'll likely be sorted in one visit rather than several that is often the case with LR dealerships. If you insist on using a LR dealership, you will get very familiar with their customer waiting area and "free" coffee.
Air suspension is not the issue it was back in the P38 days. 2012 SDV6 - it's missing a couple of cylinders
Post #628262 Tue Nov 15 2022 5:03pm
snerkler
DRW wrote:
Hi
David
Thanks for the info, much appreciated.
Post #628282 Wed Nov 16 2022 8:36pm
snerkler
Thanks. With regards to servicing and repairs I’d have to check the small print of the PCP deal as I believe some specify it has to be main dealer.
Post #628283 Wed Nov 16 2022 8:37pm
I guess if you're just renting it then it's less of a worry. 2012 SDV6 - it's missing a couple of cylinders
Post #628284 Wed Nov 16 2022 10:04pm
snerkler
With PCP you're still responsible for the upkeep.
I've seen a nice HSE dynamic with the S/C V6, is this a good engine?
Post #628308 Thu Nov 17 2022 7:47pm
snerkler
Oh, one other question. Do all HST’s have the Suede steering wheel and if so can these be swapped out for a leather one, and roughly what cost?
Post #628310 Thu Nov 17 2022 8:36pm
DRW
Wales
Hi
I have learned something today
I have not heard of a HST spec before, also I have never seen a suede steering wheel either?
I presume if you check E Bay there will be someone that has a leather steering wheel for sale, a good indy will probably swap it for you, I am unsure whether a JLR Stealer would want to take on the job of swapping second hand parts ?
Post #628603 Sat Nov 26 2022 12:25pm
snerkler
All the used 3.0l P400's all seem to be HST, I've not been able to find the 3.0l P400 in any other variant.
Post #628606 Sat Nov 26 2022 12:58pm
jimbg
It was available as HSE, HSE Dynamic and HST
PM me and I will email the specification brochure? 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #628608 Sat Nov 26 2022 1:24pm
snerkler
PM sent, thanks
Post #628613 Sat Nov 26 2022 5:05pm
