![]() | Home > General (L494) > Broken into without damage |
Tom_T Member Since: 10 Mar 2022 Location: Essex Posts: 10 ![]() |
In a word, yes. If you have keyless entry then it’s very easy for a thief to use various methods to relay the signal from your key to then get into your car. Faraday pouches will help prevent this. |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 252 ![]() |
Or turn keyless entry off! |
Amir Member Since: 09 Oct 2022 Location: Liverpool Posts: 8 ![]() ![]() ![]() |
I was far from the car! |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1176 ![]() ![]() ![]() |
@amir, it doesn't matter how far away you are, this is how the keyless thieves work:
Exactly - you only 2 laptops - 2 wifi hotspots they can pick up your key signal from anywhere, duplicate it and get into your car.
Amazing thanks guys |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9017 ![]() ![]() ![]() |
Are you also 100% sure that it was locked? 2012 SDV6 - it's missing a couple of cylinders
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 493 ![]() ![]() ![]() |
That was my question. I’ve accidentally unlocked my car after locking it because my hand tapped the handle. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 260 ![]() ![]() |
I disabled mine after reading this. So easy to do!
