Home > General (L494) > Broken into without damage
Amir
United Kingdom 2013 Range Rover Sport SDV6 HSE Java Black
Locked and Parked my car at a busy outdoor parking spot last night, came back to it a few hours later to discover someone had been in and had a good nose around! Are our cars that easy to get into?
Post #627971 Sat Nov 05 2022 10:23pm
Tom_T
In a word, yes. If you have keyless entry then it’s very easy for a thief to use various methods to relay the signal from your key to then get into your car. Faraday pouches will help prevent this.
Post #628135 Fri Nov 11 2022 6:06am
Karlp606
Or turn keyless entry off!
Post #628141 Fri Nov 11 2022 2:46pm
Amir
I was far from the car!
Post #628200 Sun Nov 13 2022 3:51am
@amir, it doesn't matter how far away you are, this is how the keyless thieves work:
When they see you park, they get close enough to detect & record the keyless signal between you & your car. Once you're away from your car, they can then send the signal back and your car unlocks.
Disable the keyless mode, it's easy to do:
Post #628204 Sun Nov 13 2022 5:40am
Karlp606
Exactly - you only 2 laptops - 2 wifi hotspots they can pick up your key signal from anywhere, duplicate it and get into your car.
For the sake of just pressing unlock/lock on your fob its worth turning it off.
Post #628237 Mon Nov 14 2022 1:09pm
Amir
Amazing thanks guys
Post #628271 Wed Nov 16 2022 3:47am
Are you also 100% sure that it was locked? 2012 SDV6 - it's missing a couple of cylinders
Post #628273 Wed Nov 16 2022 10:08am
NoExpert
That was my question. I’ve accidentally unlocked my car after locking it because my hand tapped the handle. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #628274 Wed Nov 16 2022 11:28am
Grimble
I disabled mine after reading this. So easy to do!
Disabled should be the default condition. RRS HSE Dynamic SDV6 2014
Nemo mortalium omnibus horus sapit
Post #628275 Wed Nov 16 2022 2:57pm
