Home > General (L494) > Odd request for info |
3hcp Member Since: 04 Nov 2021 Location: Devon Posts: 79 |
No but sounds much better without them.
Tue Oct 11 2022 6:33am |
Tyrefitter Member Since: 19 Jul 2015 Location: Bridlington East Yorkshire Posts: 3677 |
I removed mine but never weighed them,but they are quite heavy.I removed them hopping it would sound better but it hardly changed the sound at all,mine was the V6.I’m guessing the V8 would sound better though. Andy.
Tue Oct 11 2022 7:51am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9013 |
Why? The MGVW is well over 6t and I doubt your big tin tent is 3t is it 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Tue Oct 11 2022 8:57am |
Cornishman Member Since: 12 Jul 2018 Location: Cornwall Posts: 27 |
About 13 kegs the two.according to bathroom scales, sad I kept them but would refit if I sold , SDV6, deeper sound at low rpm on Milltek. |
Tue Oct 11 2022 9:15am |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 871 |
Van is 2.6 ton empty and 3.3 with load. Bigger issue is rear axle loads as well. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Tue Oct 11 2022 10:03pm |
Axle load caused by the trailer shouldn't really be an issue if one is following LR's nose weight limits. It should be no more than 150kg (from memory) no matter what mass the towed load is.
Wed Oct 12 2022 11:46am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5032 |
I think I recall reading nose weight limit in OZ is 350kg.
Thu Oct 13 2022 2:38am |
Towball weight is 350 kgs in OZ , and Mine runs about 329 with e bikes and load. However the towball weight mulptiplies the rear axle weight which I am assuming will add 400 kgs to rear axle weight, which doesn't leave much. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Fri Oct 14 2022 10:30pm |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 |
https://www.4wdingaustralia.com/4x4/what-i...it-matter/
Sat Oct 15 2022 7:12am |
