Home > General (L494) > Odd request for info
IRBails
Australia
I am trying to reduce vehicle weight as I tow a Large Van. According to RR the car is supposed to weigh about 2.4 ton but with passengers and fuel runs in at around 2.8. I have saved weight by going to LIPO4 batteries and am now considering getting rid of the rear Mufflers. Wondering if anyone knows the weight of these? M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #627258 Mon Oct 10 2022 10:41pm
3hcp
No but sounds much better without them.
H 2015 RRS DIESEL HYBRID
Post #627259 Tue Oct 11 2022 6:33am
Tyrefitter
I removed mine but never weighed them,but they are quite heavy.I removed them hopping it would sound better but it hardly changed the sound at all,mine was the V6.I’m guessing the V8 would sound better though. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #627260 Tue Oct 11 2022 7:51am
Re: Odd request for info
Why? The MGVW is well over 6t and I doubt your big tin tent is 3t is it 2012 SDV6 - it's missing a couple of cylinders
Post #627263 Tue Oct 11 2022 8:57am
Cornishman
About 13 kegs the two.according to bathroom scales, sad I kept them but would refit if I sold , SDV6, deeper sound at low rpm on Milltek.
Post #627264 Tue Oct 11 2022 9:15am
IRBails
Australia
Van is 2.6 ton empty and 3.3 with load. Bigger issue is rear axle loads as well. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #627298 Tue Oct 11 2022 10:03pm
Axle load caused by the trailer shouldn't really be an issue if one is following LR's nose weight limits. It should be no more than 150kg (from memory) no matter what mass the towed load is.
Ah, you're down under, aren't you? Do you have a higher nose weight limit down there? 2012 SDV6 - it's missing a couple of cylinders
Post #627317 Wed Oct 12 2022 11:46am
I think I recall reading nose weight limit in OZ is 350kg.
Post #627344 Thu Oct 13 2022 2:38am
IRBails
Australia
Towball weight is 350 kgs in OZ , and Mine runs about 329 with e bikes and load. However the towball weight mulptiplies the rear axle weight which I am assuming will add 400 kgs to rear axle weight, which doesn't leave much. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #627381 Fri Oct 14 2022 10:30pm
karlos01
https://www.4wdingaustralia.com/4x4/what-i...it-matter/
found this on line hope it helps
Post #627383 Sat Oct 15 2022 7:12am
