![]() | Home > Technical > High speed vibration help please? |
Seized EPB shoes or rear caliper/s |
Gas-guzzler Member Since: 28 Dec 2021 Location: Paisley Posts: 64 ![]() ![]() ![]() |
Thanks for the reply. That’s very interesting as I have changed the rear shoes and pads just recently. The shoes were pretty rough against the backing plate but cleaned and lubed everything up. I wonder if I’ve put something back together incorrectly?
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 493 ![]() ![]() ![]() |
Can also be worn control arm bushings. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Thank you. I’ll do some investigation over the next few days and post my findings.. |
Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163 ![]() ![]() ![]() |
Second this, was for me anyway! Sorted with Poly bushes |
Most common bushings are front end lower arm rear bushings and rear end upper arm front bushings. This doesn’t mean nothing else will be bad, but they’re the typical culprits. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Thanks guys, your input is much appreciated. I think I can rule out the rear brakes. The shoes nor the pads seem to be binding as the car rolls freely on an incline and no excessive heat build up on the disks when driven. I’ll check the aforementioned bushes. |
