Home > Maintenance & Modifications > Leaking Dynamic pipes. Can I drive home
Mccolganm4
Looking for some input please. I am currently camping about 80 miles from home and have sprung a leak in the rear dynamic response pipes near the valve block. Can I drive home? The fluid is just below the minimum, I have 5 litres at home but no real way of getting it to me to top up. It's Saturday afternoon in the middle of the Cairngorms so can't buy any. What damage will be done if it runs dry?
Thanks
Post #626392 Sat Sep 03 2022 3:54pm
Nilrem280
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
You'll run the risk of damaging the ACE pump if you run it without fluid.
About £1400 for a new one.
Post #626394 Sat Sep 03 2022 4:39pm
Mccolganm4
Didn't want to hear that. I hoped the valve block would shut off and not let fluid through when the pressure/level dropped
Post #626395 Sat Sep 03 2022 4:48pm
Disco_Mikey
Is the red warning light on yet?
Post #626396 Sat Sep 03 2022 6:10pm
Mccolganm4
Yeah, it just came on as I was parking up
Post #626397 Sat Sep 03 2022 8:13pm
Disco_Mikey
If the level is still on the minimum, there is still oil in the system.
The car is seeing a pressure loss via the leaking pipe, then loops out the actuators when it goes into fault mode
I'd run it down the road for a mile and recheck the level. If its still the same, I'd run it down the road and check it every so often
Safest option is to arrange recovery...
Post #626398 Sat Sep 03 2022 8:42pm
Mccolganm4
Cheers Mike. I've arranged to meet some 20 miles from here in the morning with a gallon of fluid. I'll keep an eye on the level and top off when I have to.
Next thing is find pipes🤣
Post #626400 Sat Sep 03 2022 9:01pm
Disco_Mikey
I keep them on the shelf, if your struggling Thumbs Up
Post #626403 Sat Sep 03 2022 10:26pm
Mccolganm4
Post #626408 Sun Sep 04 2022 7:30am
Mccolganm4
Made it home. Couple of top ups but must be a slowish leak. Just took my time and it didn't run dry so should be good with just pipes.
Are the front and rear pipes for the 4.2 sc the same as everything else?
Post #626411 Sun Sep 04 2022 12:10pm
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi good new if your getting them replaced seek advice from Disco Mikey I’m sure will offer you wise guidance not sure if he is near you but may be worth getting him to do the work .
Post #626429 Sun Sep 04 2022 5:19pm
Mccolganm4
Mikey is just down the road from me. I'm going to give him a call tomorrow and have a chat. I am a mechanic so should manage the job, although I thought my days of rolling about in the drive under cars were behind me
Post #626433 Sun Sep 04 2022 6:16pm
Disco_Mikey
Not with anything JLR Laughing
Post #626437 Sun Sep 04 2022 8:24pm
Mccolganm4
Rolling with laughter I'm noticing that mate
Post #626442 Sun Sep 04 2022 9:24pm
Iomegas
Yes agree but that’s part of the enjoyment takes me back to my younger days working on cars !mind that was when you could repair a car with hammer ,screwdrivers ,cigarette paper lol Triumph Herald ,Cortinas ,Viva ,Minis lol and such like of the period lol Thumbs Up
Post #626449 Mon Sep 05 2022 10:35am
